1995 Bongo. Anyone had both the front and rear heater blowers cease working at the same time, and on all four speeds?
Independently wired the front heater, and that motor is working ok. Fuses look ok and have been swopped around too.
I'm starting to check connections and wiring, but is there anything else that anyone can suggest?
Thanks.
Front/Rear Heater motors not blowing
Re: Front/Rear Heater motors not blowing
Now found a related earlier post on the subject which hopefully will lead to a solution.busguy wrote:1995 Bongo. Anyone had both the front and rear heater blowers cease working at the same time, and on all four speeds?
Thanks.
Would that be the transistor problem? I don't know the details, so didn't post
There's always a 'bigger picture'
if its digital is rear turned on on front pamel
lower right button
lower right button
