Plasma Dial Kit Problems
Moderator: Ian
Mark Elvin
Post by Mark Elvin » Fri Sep 19, 2014 11:48 am
Anybody had any problems with the wiring on their plasma dial kit?
The first connector on the wire from the inverter works OK, but the ones along the line do not work at all.
When I plug in the extension lead for the heater & gear selector all of the dash dials work, but not when plugged into the wiring from the inverter (other than the one connected to the first plug as I said).
I've tried contacting Visual Performance dozens of times in the last 48hrs, but there's either an answerphone (which they don't respond to) or simply no answer, they don't respond to e-mails either.
Re: Plasma Dial Kit Problems
Post by g8dhe » Sun Sep 21, 2014 2:18 pm
Not had that problem, but the company might be on holiday of course or even just the weekend?
khisanth
Post by khisanth » Fri Apr 10, 2015 10:17 am
On that same note has anyone had problems informing mot centre that the odometer now reads km rather miles
Post by g8dhe » Fri Apr 10, 2015 10:22 am
Not really it depends on the attention span of the MoT tester! It used to be an option of Miles or Km and they aren't really concerned as fr as we could see!
khisanth
Post by khisanth » Fri Apr 10, 2015 10:44 am
so if i tell them its now km they can change it on a new mot certificate
Post by g8dhe » Fri Apr 10, 2015 10:46 am
Ours seems to have switched several times over the years!
Post by Simon Jones » Fri Apr 10, 2015 12:47 pm
They used to state Miles or Km on the certificate but on my last one it was just shown as a number with nothing to indicate unit of measure.
Pompeysteve
Post by Pompeysteve » Sat Apr 25, 2015 7:26 pm
I assume it's the company in Swindon. I got mine via e bay?..they are complete pants... I've had problems with the dials, I've e-mailed, phoned left messages no joy. Avoid.
Post by Simon Jones » Sat Apr 25, 2015 8:32 pm
I bought a set from a private seller on eBay that was described as new but turned out to be used and flickered briefly before giving up. Probably a proper new set would have been more sucessful.
Return to “Pimp My Bongo”
