Sump Plug 2.5 TD 96
Sump Plug 2.5 TD 96
Need some data on sump plug thread size/depth - looking to convert to sump plug with oil temp sensor - thank you
- mikeWalsall
Re: Sump Plug 2.5 TD 96
It was asked on another Forum for some one to fit an oil temp sender and 14mm x 1.5 pitch was mentioned ..
You could also go down this route or use a flex T, using the oil pressure switch outlet.
http://www.ebay.co.uk/itm/like/T-Piece- ... RTM1889351
