I hope somebody can help me. I am looking to buy an awning for a Bongo I hope to pick up next weekend. It is a Kampa Travel pod midi and I have found a very very well priced new one and it seems to suit our needs well, but I have to buy it soon as it is the last one left.
It states that it fits rails up to 190cm. Would this fit on a 2002 tintop? I have no idea how high the awning rails are on Bongo.
Thanks for you help in advance.
Awning rail height
Moderator: Muzorewa
- Apprentice Bongonaut
Re: Awning rail height
Hopefully someone with a tintop or knowledge of whether all bongo rails are at similar height whatever age will be along soon to help.
I suspect that awning would be fine. I have just measured the height of the rail/gutter on my '96 AFT and it is 179cm off the ground, so unless Bongo heights vary much (and it could be 11cm higher and still be OK for a fit) I can't see a problem.
If you're not sure, can you get the person you are buying the bongo from to measure the height of the rail for you?
Keep Calm and Bongo On!
Just measured mine. 180cm at the B post and 185 at the very rear. I have aftermarket 17" wheels but the diameter is pretty close to standard fitment. I'd guess that you shouldn't have any problem staying within 190cm.
Thank you both. Got the awning, think it will fit fine. I was going to email the guy I'm buying it off but hassled him enough
. I appreciate the replies.
How did you get on with this awning? I went to the NEC yesterday and was also interested in this type.
