leisure battery
john787030
leisure battery
Post by john787030 » Fri Aug 29, 2014 10:52 am
hi all i need a new one any suggestions?
Re: leisure battery
Post by Simon Jones » Fri Aug 29, 2014 12:33 pm
What type/size have you got now? Generally, it's best to go for the highest capacity you can, but something like a 110A unit may be too large for your battery tray.
Puma931
Re: leisure battery
Post by Puma931 » Thu Jan 29, 2015 8:44 pm
I bought mine from eurocarparts 110ah Lion for £79 which has a 3 yr warranty. Solar panel keeps it charged and I'm swapping the lights and stereo feeds over to the LB.
Dodgey
Re: leisure battery
Post by Dodgey » Fri Jan 30, 2015 12:09 pm
dobby
Re: leisure battery
Post by dobby » Fri Jan 30, 2015 7:04 pm
Dodgey wrote:I put a lot of these in :
http://www.tayna.co.uk/Numax-CXV31MF-P3694.html
Dodgey - do these fit the standard winter pack battery tray?
Dodgey
Re: leisure battery
Post by Dodgey » Sat Jan 31, 2015 9:45 pm
I doubt it - I usually use deeper aftermarket trays - people generally come to me with aWillinton kit fitted, with their deeper tray, or I fit an ebay one , though you can check the measurements. Do bear in mind the battery can sit higher than you might think.
dobby
Re: leisure battery
Post by dobby » Sat Jan 31, 2015 11:09 pm
Cheers will do, probably go like for like with existing LB
dave_aber
Re: leisure battery
Post by dave_aber » Sun Feb 01, 2015 8:46 am
Also note that battery has the terminal orientation such that to get the + to the left, they are at the front - closer to the bonnet. You'd get away with a (slightly) bigger battery if the terminals were the other way round.
Image...Image
dobby
Re: leisure battery
Post by dobby » Sun Feb 01, 2015 11:34 am
Thanks Dave
nth
Re: leisure battery
Post by nth » Tue Feb 24, 2015 2:36 pm
The one that was in my bongo when i bought it finally gave up so just bough this 115ah one from Halfords
http://www.halfords.com/car-seats-trave ... ery-115-ah
It's a very snug fit but does go in. Got it for £72 on trade :D
95 2.5d 4WD AFT
scanner
Re: leisure battery
Post by scanner » Tue Feb 24, 2015 2:41 pm
How on earth do you manage to get nearly £60 off at Halfrauds :shock:
nth
Re: leisure battery
Post by nth » Tue Feb 24, 2015 4:12 pm
scanner wrote:How on earth do you manage to get nearly £60 off at Halfrauds :shock:
With a Halfords trade card, its not a fixed discount it depends what you buy, their own brand stuff including tools gets you the best discount. The mark up on some things is actually shocking. A pack of 2 sidelight bulbs that normally cost £2.49 you get for 49p. You can get a set of 3 own brand wiper blades for less than the price of you would pay for one.
95 2.5d 4WD AFT
Dr. Strangelove
Re: leisure battery
Post by Dr. Strangelove » Tue Feb 24, 2015 6:57 pm
Dodgey
Re: leisure battery
Post by Dodgey » Tue Feb 24, 2015 7:10 pm
What I can tell you for sure is that this:
http://www.ebay.co.uk/itm/Mazda-Bongo-F ... 4d2d78030e
works with the battery I linked.
