Switch size
Moderator: Ian
Dogran
Switch size
Post by Dogran » Tue Aug 26, 2014 12:09 pm
I'm looking to hard wire a 3 way 12v adaptor into my Bongo. I'd like to be able to switch it on and off and was thinking of replacing the switch blank below the steeering wheel on the right side (next to the rear heater switch) with a rocker switch to do this. Does anyone know the correct size of switch I need to order to fit in this space?
Thanks!
Re: Switch size
Post by g8dhe » Tue Aug 26, 2014 1:30 pm
Electrically you will need a rating greater than 10Amps for the switch, which is what the sockets are rated for. You would also be wise to put in wiring much thicker than you would expect for 10 Amps as it will be quite a long run and you will want to minimise voltage drop to the outlet.
Dogran
Re: Switch size
Post by Dogran » Tue Aug 26, 2014 5:59 pm
Thanks Geoff, all noted. I was actually wanting to know the physical size the switch should be to fit in that blank space. Any ideas?
Tony x
Re: Switch size
Post by Tony x » Tue Aug 26, 2014 6:26 pm
As an alternative, you could modify the blank switch.
Switch I used was one of these:-
http://www.ebay.co.uk/itm/181097579591? ... 1497.l2649
These switches from Halfords fit but will leave a small gap at the top or bottom.
http://www.halfords.com/motoring/garage ... ef359#tab2
Re: Switch size
Post by Simon Jones » Tue Aug 26, 2014 6:53 pm
These fit in the holes either side of the steering column without modification although you will need a relay to run a fridge: http://www.ebay.co.uk/itm/RED-LED-RECTA ... 1168368581
Re: Switch size
Post by g8dhe » Wed Aug 27, 2014 10:28 am
I must admit I couldn't find a direct replacement for the switches themselves so have added any extra switches to the blanks as well.
Dogran
Re: Switch size
Post by Dogran » Thu Aug 28, 2014 4:55 pm
Thanks both, will have a go at modifying the blank as suggested.
Re: Switch size
Post by Simon Jones » Sun Aug 31, 2014 9:09 am
There's a used switch (of the type I mentioned before) on eBay although, as is often the way, it's more expensive than a brand new one #-o:
http://www.ebay.co.uk/itm/mazda-bongo-r ... 2a42f16860
Re: Switch size
Post by mikeonb4c » Sun Aug 31, 2014 10:01 am
Simon Jones wrote:There's a used switch (of the type I mentioned before) on eBay although, as is often the way, it's more expensive than a brand new one #-o:
Bit of a joke that - looks like the (green, in my case) LED switch i've just fitted (the type in your earlier link). For info of others, the one I've fitted does sit in the space well and its clips manage to engage and hold. But it doesn't sit flush with the electric blind switches I've located it between, unlike the green illuminated rocker switch I'd had there before. The old switch though was too bright at night, used more current for its light, and required me to make it a holder made out modeller's ply painted black, which was a gaff! Overall I'm v happy with the new switch. :-)
Re: Switch size
Post by Simon Jones » Sun Aug 31, 2014 10:36 am
You're right, the bezel of the switch is very shallow so it sits quite deep in the recess. On my earlier photo, you can see I put a group of two next to each other so they all were equally inset.
Return to “Pimp My Bongo”
