I All
I have a tv in my bongo but I think the arial is not strong enough for it and I am finding it difficult to find any company that does this sort of work anyone know anything about this subject or where I could get it done
Steve Powys
TV aerial
Moderator: Ian
Re: TV aerial
Just tried out an aerial I bought from Maplins. Gives a perfect signal and the full Freeview available at home in Birmingham but here in Norfolk doesn't work on any channel. Even the best is going to have problems in an area of low signal strength.
- mikexgough
Re: TV aerial
Avtex ariel is what we use.....also has a 12v powered booster.....although...we don't seem to have much time for tv....
- Simon Jones
Re: TV aerial
Why not see what other folks have got when you're next at campsite with poor reception? There are plenty of campsites in little coves and valleys where you just won't get a decent signal so upgrading may not help.
What type of aerial are you using currently and do you have an amplifier? If you use the same TV on the aerial at home is it ok?
Re: TV aerial
Hi All
Thanks for the replies and the info its for the kids otherwise I would not bother.
Steve Powys
Steve Powys
Re: TV aerial
Hi Steve, what about something like this, i am sure the kids will be able to Stow it somewhere.
http://www.systemsat.co.uk/caravan-sate ... d-lnb.html
Re: TV aerial
thanks for the suggestion
Steve Powys
Steve Powys
