Newbie problem with Power Management System PMS 3V
Moderator: Muzorewa
Hi just got my first ever Bongo yesterday. It had been lying unused for 15 months and I have spent £1400 getting it MOTed . I have connected it to the mains of my house and the Power Management System isn't working. The only light that comes on is Battery Selection that lights up saying Battery Condition Low. No other lights come on. Is this a leisure battery problem or something else ? Thanks in advance
Re: Newbie problem with Power Management System PMS 3V
hi did you get a user manual with the PM system if not you can down load one from the web, just google it , I did with my first bongo, then check out the wiring, bulbs, and fuses Just found it for you hope this helps .
http://www.tonhauser.com/rubbersoul//im ... Manual.pdf
Thanks for that, I've got the manual but I can't find the problem. I'm presently charging the leisure battery to see if that works.
- Simon Jones
There's a reasonable chance the LB may be knackered if it's been left in a discharged state for any time. Worth getting a multimeter on it to see what it reads both on and off charge.
