Been bugging me since I got it?
Posted: Wed Sep 20, 2006 10:23 am
by ukspaceman
Why do I have a 4WD/ABS warning light when I dont have 4WD ? Its not that I'm having any problems it just doesn't make any sense.
Posted: Wed Sep 20, 2006 10:49 am
by Simon Jones
Does the light come on when you put key in the ignition or are you just seeing the icon on the dash which is probably standard on all models?
Posted: Wed Sep 20, 2006 10:51 am
by ukspaceman
Simon Jones wrote:Does the light come on when you put key in the ignition or are you just seeing the icon on the dash which is probably standard on all models?
Light comes on when when I turn the ignition on
Posted: Wed Sep 20, 2006 12:29 pm
by Veg_Ian
But do you have ABS?
Posted: Wed Sep 20, 2006 12:42 pm
by ukspaceman
I guess so its a 96 model but I dont have 4WD
Posted: Wed Sep 20, 2006 12:48 pm
by Veg_Ian
Then I guess Mazda were being tight or stuck for space for an extra dashlight and combined the ABS with 4WD. I have both but to be honest have not paid much attention to the signage on the lamp. As it is full time 4WD there isn't much point in having a light to tell me it's engaged and if it fails I think it would get noisy enough without the need for a light!
So in conclusion I guess it's a misnomer and should just read 'ABS'.
word to the wise
Posted: Wed Sep 20, 2006 1:38 pm
by crazy uncle gray g
Spaceman, I just had another thought
Good old Dandywarhol seems very up on all things technical perhaps if you gave him a BUNG he may be able to help.......................... sorry did I say BUNG I meant shout.
Posted: Wed Sep 20, 2006 5:45 pm
by Dave up north
It means you have abs on four wheels.
Nowt to do with 4 wheel drive.
My mitsubishi has the same light and the handbook says it is the warning light for the abs.
Some abs systems must be only on the front wheels, i guess.
So its a bit of "Posh" if it says 4 wheel abs.
Posted: Wed Sep 20, 2006 9:56 pm
by ukspaceman
