Hi All,
I recently bought a replacement Bongo, it did have the kitchern conversion done by JAL imports, however the last owner removed the kitchen, the electric and water hookups are still in place on the outside but no evidence of the electric connections inside, is there a typical place these would be hidden, behind a cubby hole or rear light cluster for example, I didn't fancy taking ths inside panel off to view?
Regards
Electric & Water Hookup
1997 Mazda 2.5TD 4WD AFT (Current) - The Red Slipper!
1995 Mazda 2.5TD 2WD AFT (2007- 2014 RIP)
Re: Electric & Water Hookup
No standard places. Just remove the panels, they are easy enough and mostly pop off.
- Simon Jones
This is a typical hookup socket view from the rear:
