Bongo receiving some love - advice appreciated
roosmith
Post by roosmith » Mon Aug 04, 2014 4:01 pm
The Bongo is getting some love next week following various posts on here. It is definitely having the chuffing brake/wheel investigated, a compression test, new glow plugs and cam belt.
My question is is there anything that I should get done at the same time as a precaution? e.g. water pump? There aren't any specific issues apart from a bit of lumpy cold starting, hence glow plugs and compression test as a start off. The cooling certainly seems to be working, as sat in holiday traffic in Norfolk last night the temperature went down, not up, to 94.
It's the diesel with 86000 miles.
wonkanoby
Re: Bongo receiving some love - advice appreciated
Post by wonkanoby » Mon Aug 04, 2014 4:15 pm
unless done before i would do the 4 main hoses between rad and engine
and the one comes of block drivers side and goes over starter motor
and get him to look at others
as these are most prone to going pop
water pump might not be a bad idea
but most important get them to flush it,inc back flushing the 2 heater rads and main one
roosmith
Post by roosmith » Mon Aug 04, 2014 4:24 pm
Hoses isn't a bad shout. I know the previous owner spent a fortune on pipework, as I have the receipts but I think it was all aircon related. Mike Gough has also looked over it and couldn't see any hoses looking old but that was a year ago. Perhaps worth another check.
The flush, again isn't a bad shout but apart from running slightly hotter than some others (subjective) I'm a little apprehensive to mess with a Bongo cooling system that is working correctly!
wonkanoby
Post by wonkanoby » Mon Aug 04, 2014 4:26 pm
then you have a choice to make do it or not
but either way get one of haydens alarms
roosmith
Post by roosmith » Mon Aug 04, 2014 4:30 pm
Well indeed!
Haydn combined alarm fitted many happy months ago :)
wonkanoby
Post by wonkanoby » Mon Aug 04, 2014 4:38 pm
they are brilliant
radiator developed a pin hole some time back
but alarm kicked of evan before gauge evan though mines been modified
if i knew back when i got bongo many years ago now i would have ripped out all the cooling pipes inc metal ones
instead of doing them one by one
as they burst
Post by mikeonb4c » Mon Aug 04, 2014 5:35 pm
roosmith wrote:Hoses isn't a bad shout. I know the previous owner spent a fortune on pipework, as I have the receipts but I think it was all aircon related. Mike Gough has also looked over it and couldn't see any hoses looking old but that was a year ago. Perhaps worth another check.
If hoses ok I'd consider treating it instead to a new radiator as I'm not sure how effective backflushing is and some owners have reported cooler running after fitting one where there was evidence of poor system maintenance. Did Mike give a view in that?
mikexgough
Post by mikexgough » Mon Aug 04, 2014 10:01 pm
The brake problem could be the caliper guide pins....a bit dry so not allowing the pad(s) to properly clear the disc....
Hoses...worth the usual check on the usual suspects....but they were fine last year as you say...
I bet a new set of glowies will sort the lumpy starting...
I'd consider a preventative radiator change at your next coolant change...if the hoses are found to be fine...
No point in "breaking" a system down unless you need to.... :wink:
roosmith
Post by roosmith » Tue Aug 05, 2014 7:07 am
Thanks for the replies. All great feedback.
I think as I do run a couple of degrees higher perhaps next year a hose and radiator replacement will be the way forward. Just have to get the arches done before then!
Hopefully it is just the caliper pins, Mike. That would be handy rather than new discs.
On the subject of discs has anyone tried an aftermarket upgrade? Things like the black diamond discs, drilled and grooved etc? I'm just interested as if I have to change them I might consider it. Towing a caravan the brakes on the caravan put the brakes on the Bongo to shame! Crazy when you can stop quicker with a caravan than without!
wonkanoby
Post by wonkanoby » Tue Aug 05, 2014 7:44 am
ive never seen a post were any one found them
roosmith
Post by roosmith » Tue Aug 05, 2014 8:11 am
wonkanoby wrote:ive never seen a post were any one found them
Found them, or fitted them? If you go on ebay there are plenty of different versions of black diamond ones at least.
Post by mikeonb4c » Tue Aug 05, 2014 8:16 am
roosmith wrote:Thanks for the replies. All great feedback.
Interesting. I do recall getting brake fade on the Bongo after an hour up and the the Yorkshire Dales heavily loaded. I use the d/s/l/HOLD combinations as much as possible since then to keep brakes as rested/cool as possible in hilly country.
If you're caravan towing then extra cooling for the autobox might be good - bf gearbox specialist Alacrity always advocated that.
roosmith
Post by roosmith » Tue Aug 05, 2014 8:24 am
The brakes don't fade, they're always half ar**d! Not quite fair, but my everyday driver is a modern car with "on/off" brakes. No feel and no effort required, so getting into the Bongo where you really have to put some effort in, I notice it!!
Again the caravan is a lot newer than the Bongo and the brakes work very well on it. I don't think there is a problem with the Bongo (the garage who MOTed it said it performed exactly the same as every other Bongo they had tested).
I'd just be interested before I spent double on a set of "upgrades" whether it was worth it.
With regards to autobox cooling, it is performing just fine at the moment, with no overheating and while there are more pressing things I've got to prioritise spending money on them. I should get round to additional box cooling by 2016 for the Bongo's 20th birthday!
wonkanoby
Post by wonkanoby » Tue Aug 05, 2014 8:31 am
have to say mine seem fine
http://www.ebay.co.uk/itm/Mazda-Bongo-2 ... _757wt_952
but they seem cheap enough to give a try
http://www.dcperformance.co.uk/uprated/ ... bongo.html
they are a lot more
Post by mikeonb4c » Tue Aug 05, 2014 10:03 am
roosmith wrote:The brakes don't fade, they're always half ar**d! Not quite fair, but my everyday driver is a modern car with "on/off" brakes. No feel and no effort required, so getting into the Bongo where you really have to put some effort in, I notice it!!
It's all relative I guess. Having started out with Morris 1000 brakes I find the Bongo as good as the Cavaliers I had in the 1990s as a firm's car. I think we maybe rely too much on brakes these days instead of thinking ahead. Mind you, we often don't have much choice on the overcrowded impatient roads of today :roll:
How do you know the autobox is at normal temp?
