1996 Front side lights
Posted: Sat Aug 02, 2014 6:10 pm
by zippy
I have fogs and the front bars on my Bongo, but the front sidelights don't come on, only the rear.
There no aircon mainbeam or fogs relay.
If the relay broken, would all lights work or none at all?
Re: 1996 Front side lights
Posted: Sat Aug 02, 2014 8:21 pm
by mikeWalsall
Maybe different for different models my V6 relays are like this ..
Posted: Sat Aug 02, 2014 9:16 pm
by Northern Bongolow
are the relays on the other side behind the starter batt.
Posted: Sat Aug 02, 2014 10:40 pm
by zippy
another fuse box and 1 relay on the side behind battery.
Posted: Sat Aug 02, 2014 11:17 pm
that will be the glow plug relay, that will be heard while starting from cold.
Posted: Sat Aug 02, 2014 11:28 pm
by Simon Jones
Assume you've checked the bulbs? You should hear a click from the respective relays when you put side / dipped / main beam on.
Interesting bit of mains cable used on the leisure battery :? May be a sign that the electrics have been monkied around with in the past.
