1996 Front side lights
zippy
Post by zippy » Sat Aug 02, 2014 6:10 pm
I have fogs and the front bars on my Bongo, but the front sidelights don't come on, only the rear.
There no aircon mainbeam or fogs relay.
If the relay broken, would all lights work or none at all?
Toyota Alphard - Bongo spirit
mikeWalsall
Re: 1996 Front side lights
Post by mikeWalsall » Sat Aug 02, 2014 8:21 pm
Maybe different for different models my V6 relays are like this ..
Post by Northern Bongolow » Sat Aug 02, 2014 9:16 pm
are the relays on the other side behind the starter batt.
zippy
Post by zippy » Sat Aug 02, 2014 10:40 pm
another fuse box and 1 relay on the side behind battery.
Post by Northern Bongolow » Sat Aug 02, 2014 11:17 pm
that will be the glow plug relay, that will be heard while starting from cold.
Post by Simon Jones » Sat Aug 02, 2014 11:28 pm
Assume you've checked the bulbs? You should hear a click from the respective relays when you put side / dipped / main beam on.
Interesting bit of mains cable used on the leisure battery :? May be a sign that the electrics have been monkied around with in the past.
