My Bongo have abs?
zippy
My Bongo have abs?
Post by zippy » Sat Aug 02, 2014 6:07 pm
Does my bongo have abs?
Missing both ABS fuses and the Main.
Toyota Alphard - Bongo spirit
dave_aber
Re: My Bongo have abs?
Post by dave_aber » Sat Aug 02, 2014 6:56 pm
Put the front wheels on full lock, and send us a photo of the inside of the hubs (2WD) or front CV joints (4WD).
Image...Image
zippy
Post by zippy » Sat Aug 02, 2014 7:17 pm
noticed 2 problems underneath :/
the laird
Post by the laird » Sat Aug 02, 2014 7:56 pm
Ain't no exciter rings so don't look like its abs .steering rack boots burst ,easily replaced and not too expensive
mikeWalsall
Post by mikeWalsall » Sat Aug 02, 2014 8:14 pm
Under bonnet ..
ABS pump / valve block lower N/S inner panel..
zippy
Post by zippy » Sat Aug 02, 2014 8:37 pm
Oil getting out from that boot? and onto the air con radiator?
Am i missing the main fuse then? And what does that one do?
Only electrics from what i tested so far that doesn't work, is the front side lights (different post for that) and rear fans.
These fans exit just behind the front seats in the roof liner vents.
Post by Northern Bongolow » Sat Aug 02, 2014 9:05 pm
the oil on the intercooler may just need the clip above tightening up, or remove the intercooler altogether then wash out any collected oil thats in there.
the steering rack maybe leaking from the seal where the shaft comes down into the rack and running down, lift the rubber seal (top hat shaped) around the shaft to check.
mikeWalsall
Post by mikeWalsall » Sat Aug 02, 2014 9:15 pm
If you do not have the ABS fuse .. pump / valve block .. the toothed cog / wheel sensers .. then you do not have ABS fitted ..
Post by Simon Jones » Sat Aug 02, 2014 9:24 pm
This is a view of nearside 2WD hub and you can see the ABS ring (which I think it fitted as standard on yours) and the sensor going off to the top (which I can't see on yours)
Post by teenmal » Sun Aug 03, 2014 10:03 am
It doesn't have ABS , but it does have serious PS steering rack problems. When is the MOTT due.
Post by Simon Jones » Sun Aug 03, 2014 10:11 am
The damp patch behind the brake caliper needs checking out too.
