Washer pump
Posted: Mon Jul 28, 2014 2:16 pm
by Nutcase
Hi guys my washers have stopped working but when power put to pumps they work and all fuses seem Ok, which is the actual washer pump fuse, any help or advice would be a great help.
Re: Washer pump
Posted: Mon Jul 28, 2014 5:03 pm
by Gasy
Blocked spray nozzles or water tubing is blocked
Blow it through
Re: Washer pump
Posted: Mon Jul 28, 2014 5:37 pm
by francophile1947
There's a fuse fact sheet in member's area 8)
Re: Washer pump
Posted: Mon Jul 28, 2014 5:43 pm
by Gasy
Fuse 13 is rear wipers and wash
Fuse 15 is front wipers and wash
Start top left
In fuse box next to drivers knee
So if your wipers are working it's not your fuses
Re: Washer pump
Posted: Mon Jul 28, 2014 6:42 pm
by Simon Jones
Compatible direct replacement pump can be bought for under £10. Plenty of info and examples via the search facility.
Re: Washer pump
Posted: Wed Jul 30, 2014 1:55 am
by Nutcase
Cheers guys, I'll check them out this weekend, thanks
Re: Washer pump
Posted: Wed Jul 30, 2014 8:01 pm
by Northern Bongolow
test with a test light to see if there is live at the plug when washers pressed, if yes then it maybe an earth fault, these are found just at the side of the headlights,look for 2-3-4 wires going into a block that is bolted to the front panel, could just need a clean as they are a bit in the weather zone.
