Starting but only clicks
TheBteam
Post by TheBteam » Sun Jul 27, 2014 8:17 pm
Hi we don't use the Bongo around town so it sits for long periods unused. When we try to start it it clicks instead of starting. I've tried charging the battery but this doesn't work, however it always works with a jump start. Do we need a new battery or is there something else we should be thinking about? Typical before the summer holidays!!
Be the change you want to see in the world....
daveblueozzie
Re: Starting but only clicks
Post by daveblueozzie » Sun Jul 27, 2014 8:29 pm
Sounds like you have a problem with the starter motor.
Lost without my Bongo.
mikeWalsall
Post by mikeWalsall » Sun Jul 27, 2014 8:39 pm
If the battery is OK and relevent lecky leads clean .. bright and tight .. maybe the contacts inside the starter motor need cleaning or replacing .. (kits are easily obtained from ebay)
I did my Toyota recently .. which as a similar starter to the Bongo and a very simple job to do ..
I recomend that you do one side at a time so you do not mix the insulaters / contacts .. and do not overtighten the connections as you may crack the insulaters and / or put the contacts out of horizontal line ..
http://www.youtube.com/watch?v=5pnySma88gY[/quote]
Post by Simon Jones » Sun Jul 27, 2014 8:41 pm
Could be the solenoid contacts need replacing (as Mike says), but if you need to jump start it then it may indicate a battery on its way out. If the battery is faulty then it won't matter how much you charge it. Can you check the voltage with a multimeter?
Dodgey
Post by Dodgey » Sun Jul 27, 2014 9:18 pm
If it starts always on a jump start, and always just clicks when on it's own power, your battery is dead. It doesn't matter if it shows 12.6 volts, if it's dead it can read full but provide no useable power.
It sounds like your dead battery is pushing the starter solenoid but hasn't got the gumpf to actually turn the engine over.
You could easily diagnose this by putting a different battery in and testing it.... but you already are doing this when you have a jump start. You are plugging the other vehicle's battery (and alternator) into yours.
Post by Bob » Sun Jul 27, 2014 9:34 pm
Yep, battery.
TheBteam
Post by TheBteam » Mon Jul 28, 2014 10:51 am
Thanks so much for all your replies will try a new battery tonight and see what happens!
TheBteam
Post by TheBteam » Wed Jul 30, 2014 9:11 am
Thanks for all the advice turns out it was the battery, the original battery (Bongos 02 plate) gave up the ghost!
Post by Bob » Wed Jul 30, 2014 10:13 pm
Done pretty well, then.
Glad you're fixed. :)
