cam/timing belt advice please
Posted: Fri Jul 25, 2014 6:49 pm
by 2newbies
HI everyone,I'm looking to have the cam/belt timing belt changed, and I was wondering if anyone can give me some advice on afew points....firstly,does the cooling system have to be broken into,(i'm planning to use the chap who services our other car and also the bongo, I would rather he doesn't get involved with the cooling system).
Secondly,can the belt be changed from underneath if put on a ramp rather than taking the centre console etc off........many thanks Paul.
Re: cam/timing belt advice please
Posted: Fri Jul 25, 2014 6:59 pm
by Bob
I'm pretty sure:
1 - No
2 - No
Posted: Sat Jul 26, 2014 6:32 pm
by 2newbies
hi ,Thanks for that,I shall go ahead......thanks again Paul
Posted: Sun Jul 27, 2014 11:12 am
by Simon Jones
What engine? For a diesel you don't need to break into the coolant and you can do most of it from below, but it's much easier to take the centre 'saddle' off so you have full access. You could also check the valve clearances while you're at it.
Factsheet covering process in the member area:
http://www.igmaynard.co.uk/bongo/member ... ambelt.pdf
May be worth taking opportunity to change the water pump while you've got it all apart.
Posted: Sat Aug 02, 2014 9:56 pm
by Diplomat
I'm planning to replace the cam belt soon (diesel).
Wondering if it makes sense to replace the cam shaft seal at the same time or are the two jobs vastly different?
I'm assuming that the ubiquitous 'Bongo weep' is via this seal.
Then there's the water pump as another 'might as well while we're at it'. Is the list likely to be never ending?
Frank
Posted: Sat Aug 02, 2014 10:03 pm
by Northern Bongolow
Posted: Sun Aug 03, 2014 9:31 am
by Diplomat
Thanks.
What
doesn't help is living in a Bongo expertise free zone!
Last cam belt I did myself was on a 1983 Honda Quintet (absolute doddle), not so sure about something I can't look at in a straight line and I didn't need reading glasses back then either.
Frank
Posted: Sun Aug 03, 2014 11:37 am
Diplomat wrote:
Thanks.
What
Frank
im exactly the same frank, its the only thing thats stopping me from doing mine, if i could just look at it square on i would be happy, virifocal glasses and all that
i just need someone to hold my hand
Posted: Sun Aug 03, 2014 1:07 pm
by helen&tony
