cam/timing belt advice please
2newbies
Post by 2newbies » Fri Jul 25, 2014 6:49 pm
HI everyone,I'm looking to have the cam/belt timing belt changed, and I was wondering if anyone can give me some advice on afew points....firstly,does the cooling system have to be broken into,(i'm planning to use the chap who services our other car and also the bongo, I would rather he doesn't get involved with the cooling system).
Secondly,can the belt be changed from underneath if put on a ramp rather than taking the centre console etc off........many thanks Paul.
Re: cam/timing belt advice please
Post by Bob » Fri Jul 25, 2014 6:59 pm
I'm pretty sure:
1 - No
2 - No
2newbies
Post by 2newbies » Sat Jul 26, 2014 6:32 pm
hi ,Thanks for that,I shall go ahead......thanks again Paul
Post by Simon Jones » Sun Jul 27, 2014 11:12 am
What engine? For a diesel you don't need to break into the coolant and you can do most of it from below, but it's much easier to take the centre 'saddle' off so you have full access. You could also check the valve clearances while you're at it.
Factsheet covering process in the member area: http://www.igmaynard.co.uk/bongo/member ... ambelt.pdf
May be worth taking opportunity to change the water pump while you've got it all apart.
Diplomat
Post by Diplomat » Sat Aug 02, 2014 9:56 pm
I'm planning to replace the cam belt soon (diesel).
Wondering if it makes sense to replace the cam shaft seal at the same time or are the two jobs vastly different?
I'm assuming that the ubiquitous 'Bongo weep' is via this seal.
Then there's the water pump as another 'might as well while we're at it'. Is the list likely to be never ending?
Frank
They flew, I took up naturism
Post by Northern Bongolow » Sat Aug 02, 2014 10:03 pm
all sounds like a good idea frank.
this may help.
Diplomat
Post by Diplomat » Sun Aug 03, 2014 9:31 am
Northern Bongolow wrote:all sounds like a good idea frank.
this may help.
Thanks.
What doesn't help is living in a Bongo expertise free zone!
Last cam belt I did myself was on a 1983 Honda Quintet (absolute doddle), not so sure about something I can't look at in a straight line and I didn't need reading glasses back then either.
Frank
Post by Northern Bongolow » Sun Aug 03, 2014 11:37 am
this may help.
Thanks.
Frank
im exactly the same frank, its the only thing thats stopping me from doing mine, if i could just look at it square on i would be happy, virifocal glasses and all that #-o :roll: :lol: :lol: :lol:
i just need someone to hold my hand :oops: :oops:
helen&tony
Post by helen&tony » Sun Aug 03, 2014 1:07 pm
I did mine from the top....and that business with varifocals I know too well... :lol: :lol: :lol: ...regarding the mirror....err....I took 3 days to do mine, as I can't bend for long, and the ol' joints play up...SO...I took several goes at looking at the mirror on different occasions, and at the last "effort", got 2 other opinions.... :lol: :lol: :lol: :lol: ...It seems we were right!...It went much better afterwards! :lol: :lol: :lol: :lol: ...mind you, it was like the blind leading the blind sighting along an imaginary rifle barrel!!!!
