Hi anybody got an idea why these lights dont work. I havnt changed the bulbs but they look ok. Main cabin and driver courtesy lights work. Are they on different fuses?
Ciao Jonny
AFT light and interior tailgate light not working.
- Bongonaut
Re: AFT light and interior tailgate light not working.
There on the same fuse as the others, I would check the bulbs.
mine are wired into the mazda kitchen unit so only work when turn the leisure battery isolater on
- mikexgough
g8dhe wrote:There on the same fuse as the others, I would check the bulbs.
+1.... check the simple stuff first.... always....
if not the bulbs ....the fuse....
then the wiring....
check the switch which enables power to the AFT light ...after...the roof is part raised..... and interior rear light...check the "pinch" cable protector...wires do get broken inside the rubber sleeve...
