valve clearance top dead centre
I want to adjust my valve clearance (2.5 TD engine) but not sure how to get the cylinders to TDC ? I've previous experience of petrol engines which was simply a case of removing the plugs , transmission in neutral and rotate each cylinder in turn using a socket on the end of the crankshaft. The 2.5 td with automatic transmission is a different beast though, any advice much appreciated.
- Driver+Passengers
Re: valve clearance top dead centre
You may need a large 38mm socket and long bar.
Driver+Passengers wrote:You may need a large 38mm socket and long bar.
And remove the heater plugs for ease of turning the engine.
- Simon Jones
You should be able to tell by the position of the camshaft / crankshaft & valves. You can also remove an inspection cover to view the flywheel markings too. I don't have the exact details to hand but the engine manual covers the methods.
