Wound Up Differential
Post by Ian » Thu Jun 05, 2014 11:09 pm
I've had the same query twice this week from different Bongonauts, here's the second one:
"I recently purchased a 98 2.5td 4wd bongo. After about 500 miles my front diff overheated and was totally destroyed. I had a replacement fitted but my first journey over 20miles it overheated again and locked up.Thinking that I had bought a dud I fitted a 3rd but again my first journey over 15miles and it overheated and locked up. Both replacement diffs were checked and oil changed prior to fitting. Can you please help?"
I haven't answered this yet, but have spoken to Andy at AVA about similar issues in the past, and am I right in thinking that this is likely to be caused by wrong tyre sizes?
Re: Wound Up Differential
Post by Bob » Thu Jun 05, 2014 11:44 pm
That's my first thought, but I would have thought damage more likely to the viscous coupling.
Tyre size would be the first thing to check. Easy and free to look and report back.
BigPanzer
Post by BigPanzer » Fri Jun 06, 2014 7:28 am
Different rolling radius tyres on front wheels? One worn, one new?
Peter
Post by Simon Jones » Fri Jun 06, 2014 8:56 am
Tyres with different rolling circumferences are the most likely cause, while seized VC is another possibility. Keeping the tyre sizes balanced all round is such a widely discussed topic that you would hope that people would be more aware of the implications of getting it wrong.
http://www.igmaynard.co.uk/bongo/forum/ ... php?t=6526
http://www.igmaynard.co.uk/bongo/member ... /tyres.pdf
Post by rita » Fri Jun 06, 2014 9:30 am
Sound like they need to do another Torque test on the VC.
mfc1476
Post by mfc1476 » Sat Jun 07, 2014 11:17 am
can anyone tell me where the vc is located and also is there a test to check the transfer box.
Post by teenmal » Sat Jun 07, 2014 12:24 pm
mfc1476 wrote:can anyone tell me where the vc is located and also is there a test to check the transfer box.
The VCU is inside the transfer box, you can carry out various Torque test to check the operation of the unit.
Rather than try to explain the procedure you can get plenty info from 4x4 Forum and utube, google etc.
PS, these procedures should always be carried out when there is a Diff wind up problem, other wise you will just be throwing money down the drain.
Good Luck
mfc1476
Post by mfc1476 » Sun Jun 08, 2014 12:43 pm
Thanks will just replace the transfer box complete.
Post by Northern Bongolow » Sun Jun 08, 2014 1:01 pm
try checking the oil in it or changing the oil, it may be a cheap fix. it its running hotter than normal it may lock earlier.
mfc1476
Post by mfc1476 » Mon Jun 09, 2014 1:39 pm
Done the vc test and its seized can you 1. replace the vc only 2. Replace transfer box only or 3. Do you have to replace the whole gear box Also if anyone could point me in the right direction for parts.
Driver+Passengers
Post by Driver+Passengers » Mon Jun 09, 2014 1:50 pm
Try George (again?)
http://www.igmaynard.co.uk/bongo/forum/ ... =5&t=65718
I think your easiest option is to source and replace the transfer box and VC assembly.
Definitely worth triple checking the rolling circumference of all four tyres before you try running with anything else replaced, if you haven't already.
Image Image
mfc1476
Post by mfc1476 » Mon Jun 09, 2014 2:22 pm
Checked tyres and there was 4" of difference.I now have 4 new wheels and tyres on my problem now is sourcing a transfer box and vc assembly.
Post by teenmal » Mon Jun 09, 2014 2:27 pm
mfc1476 wrote:Done the vc test and its seized can you 1. replace the vc only 2. Replace transfer box only or 3. Do you have to replace the whole gear box Also if anyone could point me in the right direction for parts.
HI, are you Craig74 on The Bongo Forum, if so I will send you a PM.
mfc1476
Post by mfc1476 » Mon Jun 09, 2014 3:00 pm
Yes that's me
Post by teenmal » Mon Jun 09, 2014 3:24 pm
mfc1476 wrote:Yes that's me
Sent 2x
