Wiring query
Moderator: Muzorewa
andymb
Wiring query
Post by andymb » Wed Jun 04, 2014 7:54 pm
Running a 240v fridge in the bongo which pulls 75w, obviously this runs when on a hook up.
I want to run it off of the leisure battery through an inverter for when were on days out. I've got a 500w inverter to take care of the initial zap which works fine when connected via the clamps to the battery terminals. But my plan was to run it off of a 12v cigarette socket (off of the leisure battery) and for some reason it won't work (alarms saying the battery is low) any ideas why? I assumed that a 12v feed off of the battery would be the same as connecting direct to the terminals. If I can it would save me wiring from the bonnet to the boot.
Any advice
Re: Wiring query
Post by g8dhe » Wed Jun 04, 2014 8:01 pm
The max. current a socket is rated for is only 10 Amps which translates to 120Watts, with the efficiency of the inverter (<90%) and the current surge when the motor in the fridge starts you will be requiring a lot more than can be supplied by the socket and wiring. At 75 Watts average running (about 6 Amps) and say a 90AmpHour leisure battery then you will only get about about 10-15 hours running from the battery until it is totally flat - its normal to only run a L/B down to about half capacity if you want it to last which is even less about 7-8 hours running.
GreenBongo
Re: Wiring query
Post by GreenBongo » Wed Jun 04, 2014 8:28 pm
You may find that the wiring to the inverter isn't substantial enough so you are getting a fair sized voltage drop, hence the alarm.
andymb
Re: Wiring query
Post by andymb » Wed Jun 04, 2014 8:35 pm
Ah that makes sense, will probably only need the fridge for the 3-4 hours we park up at the beach so will have to run a cable off of the LB. what cable would you suggest?
blobber
Re: Wiring query
Post by blobber » Wed Jun 04, 2014 9:53 pm
Personally, I wouldn't bother with all that faffing about for 3-4 hrs use. I'd put a frozen coolpack in a couple of hours before going to bring the temp. down, and then swap it with a fresh one when stocking up. Should stay cool long enough.
Alan & Dot
Yes sir, I can Bongo !!
andymb
Re: Wiring query
Post by andymb » Wed Jun 04, 2014 10:40 pm
Know what your saying blobber but sort of sold the bongo to the wife as a kitchen on wheels.
Re: Wiring query
Post by g8dhe » Thu Jun 05, 2014 10:29 am
Mount the inverter as close as possible to the battery, and then run the mains to the fridge there are less losses that way.
winchman
Re: Wiring query
Post by winchman » Thu Jun 05, 2014 11:53 am
Is it a compressor or absorption fridge?
Compressors are noisy absorption is silent.
I have a Dometic DS200 fridge, its 65w and totally silent, they run fine from a 150w inverter so I would have thought a 500w would be too big and just cause you more losses?
