Hold Light
Morvern
Hold Light
Post by Morvern » Wed Jun 04, 2014 10:20 am
Please can someone tell why this light occasionally comes on?
Re: Hold Light
Post by g8dhe » Wed Jun 04, 2014 10:27 am
If its a steady light probably because you have operated the switch on the gear stick ?
However if its FLASHING then it indicates that the ECU for the gears has found a problem.
jimmo62
Re: Hold Light
Post by jimmo62 » Wed Jun 04, 2014 11:04 am
Interestingly....
I swapped fuses 1 and 8 to my Leisure battery. If the LB now gets completely discharged I get the hold light flashing. I need to check the wiring diagrams to try to understand why - but at least the fix is simple!
Re: Hold Light
Post by g8dhe » Wed Jun 04, 2014 11:23 am
Yes the Top Left 10 Amp fuse handles demands for unswitched supplies which includes the backup to the ECU (which causes the hold light to flash), Radio, Door lock, AFT and many other low current circuits.
Re: Hold Light
Post by Simon Jones » Wed Jun 04, 2014 1:25 pm
If your LB is getting completely discharged, then it's going to be knackered by now :(
Driver+Passengers
Re: Hold Light
Post by Driver+Passengers » Wed Jun 04, 2014 1:30 pm
Simon Jones wrote:If your LB is getting completely discharged, then it's going to be knackered by now :(
I thought that was the point of an LB - "deep cycle"?
Image Image
Morvern
Re: Hold Light
Post by Morvern » Wed Jun 04, 2014 1:47 pm
Many thanks for your replies. I think I must knock the button on the gear stick or there is a loose wire? The light came on last night during a short journey and stayed on. When I returned the light did not come on! As far as I am aware my leisure battery is fine. At least now I know what the light is for. Thanks again.
Re: Hold Light
Post by Muzorewa » Wed Jun 04, 2014 1:56 pm
But during a journey surely you'd notice that you were no longer in top gear?
Re: Hold Light
Post by francophile1947 » Wed Jun 04, 2014 6:17 pm
Modern LBs aren't deep cycle, they're more like heavy duty starter batteries and even have a cranking amps reading. A true deep cycle battery is very unlikely to be able to start a Bongo, as it's meant to release it's power slowly.
Driver+Passengers
Re: Hold Light
Post by Driver+Passengers » Wed Jun 04, 2014 8:30 pm
I admit, I haven't looked into it though need to as I want to change the setup I've got - but again, I thought that was the point, split charge relay, isolating circuits, etc... high cranking starter battery on the driver's side, deep-cycle slow-release leisure battery on the passenger's side - ie it's "ok" to run the LB down when parked up, but you'll only and always turn the engine over with the starter battery. I thought LB and deep-cycle were synonymous. (Waaaay off topic though, sorry).
Image Image
Re: Hold Light
Post by francophile1947 » Wed Jun 04, 2014 9:21 pm
Driver+Passengers wrote: I admit, I haven't looked into it though need to as I want to change the setup I've got - but again, I thought that was the point, split charge relay, isolating circuits, etc... high cranking starter battery on the driver's side, deep-cycle slow-release leisure battery on the passenger's side - ie it's "ok" to run the LB down when parked up, but you'll only and always turn the engine over with the starter battery. I thought LB and deep-cycle were synonymous. (Waaaay off topic though, sorry).
Correct
Used to be like that, when you got proper deep cycle batteries
Driver+Passengers
Re: Hold Light
Post by Driver+Passengers » Wed Jun 04, 2014 9:37 pm
Cheers.
Image Image
