Switch
Posted: Mon Jun 02, 2014 11:17 am
by stpn666
Hi All
I have discovered a switch in my roof when raised it says cancel lock can anyone explain what this switch is for?
Steve Wales
Re: Switch
Posted: Mon Jun 02, 2014 11:24 am
You need to press this switch to allow the roof to lower! Its a safety device, to make sure you check what's in the roof before lowering it! The roof will also stop half way down and will require the normal raise/lower switch to be released and pressed again to complete lowering again a safety check to make sure that the material is laying correct and that nothing is going to jam the roof when fully lowered.
Re: Switch
Posted: Mon Jun 02, 2014 11:53 am
Looks like this is related to your other thread
http://www.igmaynard.co.uk/bongo/forum/ ... 04#p627104
The switch you mention in this thread is the Roof Lock Cancel switch, it allows you to unlock the roof to allow lowering it.
If there wasn't this safety feature you could squash a person or equipment inside the roof, just by touching the raise/lower switch ....
Re: Switch
Posted: Mon Jun 02, 2014 8:19 pm
by Simon Jones
Might be worth investing in an owners manual (around £20) which will explain all the controls for you.
http://www.igmaynard.co.uk/bongo/mercha ... tm#Manuals
Re: Switch
Posted: Tue Jun 03, 2014 8:28 am
by stpn666
Hi All
Thanks for the info very grateful
Steve
Wales
