Recommended Coolant for Diesel Bongo
ianpaull
Post by ianpaull » Mon Jun 02, 2014 8:03 am
Hi Guys
I have a 2.5L auto Diesel bongo (1997) SGL5F
The previous owner has thoughtfully fitted a coolant alarm and whilst its not going off regularly its starting to bleep a bit when not on level ground so could likely do with a top up. The manual i purchased on here just says to use genuine long life coolant but I wondered if anyone can advise on this? I've been into halfords and decided it would be best to ask first...some doctrine suggests mixing coolants is a bad idea and the whole thing should be drained, flushed and refilled but this seems a little extreme for an occasional low-level light...
Any thoughts/advice appreciated
thanks
Ian Paull
1997 Ford Freda 2.5L turbo diesel 4wd SGL5F
Re: Recommended Coolant for Diesel Bongo
Post by rita » Mon Jun 02, 2014 8:19 am
Hi Ian, universal antifreeze should be ok.
Something like this.
http://www.ebay.co.uk/itm/Bluecol-u-Uni ... 4897.l4275
Post by Bob » Mon Jun 02, 2014 8:38 am
Loosen the screws in the header tank and clean with a wire brush. The corrosion inhibitor can coat them. :wink:
Post by Northern Bongolow » Mon Jun 02, 2014 6:54 pm
this thread contains some good advice.
read the links in it too. :wink:
http://www.igmaynard.co.uk/bongo/forum/ ... it=coolant
Post by haydn callow » Tue Jun 03, 2014 8:54 am
Bob wrote:Loosen the screws in the header tank and clean with a wire brush. The corrosion inhibitor can coat them. :wink:
I think because it only beeps when not level it will be a bit low on coolant rather than a dirty screw.
ianpaull
Post by ianpaull » Wed Jun 04, 2014 8:11 am
Thanks for the advice guys, appreciated
Ian Paull
