So the,
What load rating for the wheels should I be looking at for a 2.5 2wd AFT?
Alloy Wheel Load Rating???
Moderator: Ian
Mark Elvin
- Tribal Elder
Re: Alloy Wheel Load Rating???
they are usually marked up around 690kg per wheel for the bongo. this will give about 12-1300 per axle.
given that the average aft bongo is about 17-1800kg plus stuff,fuel, etc this sounds about right plus a healthy safety margin.
in the link below it shows the load index for the tyres too.
i run on 100 load ratings all round, this gives a weight per tyre of 800 kg, again well over the top, but safe.
http://www.blackcircles.com/general/load-rating
the standard fronts for a bongo are 92 and the rears are 98 minimum, so you could work this back to give wheel load ratings
