Just bought some alloys for my Bongo. Currently on 15's but new ones are 16's.
Couple of q's:
Where can I get alloy wheel nuts from? Local motor factors scratching their heads as Bongo doesn't show on their systems.
Any tips that I need to look at when getting garage to change these over? Someone mentioned rings to me??
New alloy wheels
Moderator: Ian
- Simon Jones
Re: New alloy wheels
These are the type you need: http://www.ebay.co.uk/itm/20-X-M12-X-1- ... 27e4c72e23
You may also need spigot rings if the wheels have a larger bore that the standard size (67.1mm? can't recall exactly). Does everything else stack up for the wheels: number of holes, PCD, offset, load rating etc?
