Dist cap etc for 2.0l petrol 2002
Have found a Distributor Cap and Rotor Arm on ebay but they say are only suitable for SGE3 models. Would these fit SGEW models? Also HT lead set but only for models without a king lead - would this be OK for SGEW model. All 3 are suitable for 2.0L petrol 95 - 2006. Any help appreciated.
2002 petrol 2L
- Simon Jones
Re: Dist cap etc for 2.0l petrol 2002
Should be fine. The difference relates to vehicle spec rather than engine:
http://specs.amayama.com/mazda/bongo_friendee/2002_9/
With regard to king lead, all distributors should have one as its the only connection to the coil & it would be well worth replacing that if you are replacing other HT leads. In the case of the V6 engine, you have to order the king lead separately.
- Simon Jones
That's interesting. It suggests there are two types: with internal & external ignition coils. Might be an idea to physically count whether the dizzy cap has 4 or 5 leads attached.
