Electric heater
adamp83
Electric heater
Post by adamp83 » Mon May 12, 2014 11:19 pm
Hi all,
I have recently acquired a bongo and am thoroughly enjoying it, however I found it very cold to sleep in. When connected to a hookup I cannot run the heater without starting the engine. Can anyone recommend a good solution for heating the bongo when connected to mains electricity?
Thanks,
Adam
Re: Electric heater
Post by Simon Jones » Mon May 12, 2014 11:36 pm
Welcome to the forum :). There's lots of info on here regarding various options for heating while plugged in on hook up, bearing in mind you should avoid plugging in a stonking great fan heater as you might end up tripping the site electrics out.
Two popular options:
- Oil filled radiator which will give slow steady heat and could be left on overnight. http://www.rapidmarketingroute.com/warm ... warm/SOFR5
- Quartz / halogen heater which typically has two settings (400/800W) which gives a nice instant heat and is much lighter to carry. http://www.towsure.com/product/Electric_Quartz_Heater
Bongoplod
Re: Electric heater
Post by Bongoplod » Mon May 12, 2014 11:49 pm
Ill second Simons recommendation for the mini oil filled radiator.Ive had one 4 yrs,very toasty thru the night,no noise as with clicking thermostats on fan heaters either.
Brian
winchman
Re: Electric heater
Post by winchman » Tue May 13, 2014 6:40 am
adamp83 wrote:Hi all,
Thanks,
Adam
That sounds odd? Once the hook up is plugged in the 240v mains sockets should work, the engine should have no effect on it?
wonkanoby
Re: Electric heater
Post by wonkanoby » Tue May 13, 2014 11:30 pm
think he means vans own heater
mikexgough
Re: Electric heater
Post by mikexgough » Wed Oct 15, 2014 8:35 pm
Lidl are doing the small oil filled radiators next Monday 20th October at £19.99
http://www.lidl.co.uk/en/our-offers-249 ... l&id=17225 and at 600w will be happy on low amp hook ups too
Re: Electric heater
Post by Bob » Wed Oct 15, 2014 10:51 pm
Small radiator is cheap, easy and silent.
Like one or two girls I've been out with. :lol:
briwy
Re: Electric heater
Post by briwy » Thu Oct 16, 2014 4:14 pm
Bob wrote:Small radiator is cheap, easy and silent.
Lucky you.
Mine have always been expensive, hard work and noisy. :) :) Present one excepted of course. #-o
