water leak from thermostat cover/case
kaelan
Post by kaelan » Mon May 05, 2014 7:20 pm
Traced a water leak to the thermostat area, dripping either from joint between cover/case or somewhere in that vicinity.
Any known problems in that area so I can give the mechanic a heads up on what might need replacing?
Kevin Thomas
Bongo + Caterham = miles of smiles :)
wonkanoby
Re: water leak from thermostat cover/case
Post by wonkanoby » Tue May 06, 2014 8:35 am
gasket as such is on either side of themostat
suggest order origimal from a mazda dealer
other than that its the hose or its clips
it will need bleeding get him to watch 3x youtube videos
