Post
by dave_aber » Thu May 01, 2014 2:12 pm
Well spotted!
I completely missed the point there, and assumed front suspension.
SO, Rears - they are bolted on using bolts which you do re-use, so only cut them off if really necessary. The ones from the club shop will be decent quality links, and will have the correct dimensions.
I stand by the comments re-welding a bracket on around a rubber bush - this may still be the cause of the knocking.
Other causes are as Simon says still up for diagnosis : Exhaust clonking into the chassis, suspension bottoming out (although this is more of a huge thump than a 'knock'). Could also be the dampers past their best.
Knocking is more usually associated to the front suspension, hence my heading off down the wrong path. Make 100% sure that the knocking you are hearing is the rear, not the front.
FWIW, when I last did my rear ARB bushes, I also sheared off one bolt. Of the 2 on each bracket, the upper one is near impossible to replace, the lower is more simple, due to the relationship between the bracket and the axle tube. I was lucky, and managed to drill out the sheared stud and fit a bolt.
Those that understand
binary, and those that don't.
