Clock
Moderator: Ian
Coradia63
Clock
Post by Coradia63 » Fri Apr 18, 2014 5:04 pm
Hi All,
I put a new clock in today being looking for ages for one that would fit in the headlining I had to get it from New Zealand £21.50 including postage it seems to be of reasonably good quality build compare to some of the cheap stuff on ebay. The photos make the display look a bit funny but it isn't, I connected the permanent feed off the interior light and ran a cable to the switched + on the radio the head lining was very easy to cut with a sharp stanley knife.
http://cruisingelectronics.com/12-volt- ... -car-clock
1995 Ford Freda 2.5 TD 4x4 AFT
helen&tony
Re: Clock
Post by helen&tony » Fri Apr 18, 2014 6:57 pm
Very nice...perhaps the neatest yet!
Re: Clock
Post by Northern Bongolow » Sat Apr 19, 2014 8:36 pm
can you see it when your in bed, :wink: . just to measure your long lye more accurately. 8) 8) .
like it lots.
mantaJim
Re: Clock
Post by mantaJim » Sat Mar 21, 2015 12:48 pm
I loved the look of this clock as its in keeping with the bongo dash styling and so just took delivery of one and planning to fit in the same position. Before I go at it like a bull in a china shop (as I often do) can anyone give me any tips on how to remove the interior light without damaging it or the headlining ? I just got my finger tips under it but assume it has lugs to keep it in place.
V6 Mushroom
Re: Clock
Post by Simon Jones » Sat Mar 21, 2015 1:08 pm
Just pull it down. You find it helps to get a couple of thin pieces of plastic (such a credit/debit cards) and insert them from either side to push in the spring lugs.
Re: Clock
Post by g8dhe » Sat Mar 21, 2015 1:22 pm
Push the light fitting hard to one side, that compress one spring, and then pull down on the other side to release it.
Diplomat
Re: Clock
Post by Diplomat » Sat Mar 21, 2015 9:29 pm
I think I prefer that location to wasting a useful space in the usual cubby hole.
Frank
They flew, I took up naturism
Re: Clock
Post by Bob » Sat Mar 21, 2015 9:42 pm
Very neat indeed, well done.
stuc
Re: Clock
Post by stuc » Sat Mar 21, 2015 9:50 pm
looks like the ones in the original XR3
mantaJim
Re: Clock
Post by mantaJim » Sat Mar 21, 2015 11:41 pm
Thanks for the tips gents - got it free just need to find some time to do the job now
V6 Mushroom
novocaine
Re: Clock
Post by novocaine » Mon Mar 23, 2015 4:22 pm
how are the wires run up to the light unit (I know they are on the drivers side but are they in the pillar or behind the trim?) and can you access them easily, I have a clock I've been thinking of fitting for a while and this looks like the best place I've seen so far to be honest, but mine also does temperature and battery voltage so will have a few more wires to route than yourself. :)
mantaJim
Re: Clock
Post by mantaJim » Fri Mar 27, 2015 8:25 pm
Sorry to (re)hijack this thread but can anyone advise where on the light fitting I should take the permanent +VE feed to avoid resetting/switching off the clock every time a door is opened. Also can i take ground from the light fitting or do I need a "permanent" ground off the chassis somewhere ?
V6 Mushroom
Re: Clock
Post by Simon Jones » Fri Mar 27, 2015 8:30 pm
Run a wire from rear of fuse box behind the A pillar trim and tuck it in under the headlining. While you're there you might as well run and earth wire up the same route. That's what I do when I fit these:
mantaJim
Re: Clock
Post by mantaJim » Fri Mar 27, 2015 8:34 pm
Thanks Simon I ran ignition feed from the radio up the passenger side A pillar and should have done the same with the permanent feed from the radio at the same time
V6 Mushroom
mantaJim
Re: Clock
Post by mantaJim » Fri Mar 27, 2015 10:35 pm
Done now and working as it should - thanks again
V6 Mushroom
Return to “Pimp My Bongo”
