No front/rear screen washers
Observer
Post by Observer » Sun Apr 06, 2014 3:59 pm
Bongo was SORN 'd over the winter but kept outside and now with her MOT looming up both washers aren't working but the wipers are. As I understand it, each wiper/washer is fused separately and the fuses check out OK.
I have read loads of info on here but before I go through the procedure of battery/tray etc. removal, my question is :- if there are two pumps, is it likely that both could have seized or packed up at the same time?
Cheers, any help would be great.
Pete
My iPhone - My office
Re: No front/rear screen washers
Post by g8dhe » Sun Apr 06, 2014 4:11 pm
Are two pumps actually operating, but just not pumping water ? Take a listen by the bottle when someone else operates the switchs.
blobber
Post by blobber » Sun Apr 06, 2014 8:19 pm
Yes it is possible. I had failure on both, but, one was a seized motor, the other was the motor bushes needed a clean. Even so, battery tray etc has to come out :( :(
Alan & Dot
Yes sir, I can Bongo !!
Observer
Post by Observer » Mon Apr 07, 2014 11:19 am
g8dhe wrote:Are two pumps actually operating, but just not pumping water ? Take a listen by the bottle when someone else operates the switchs.
Thanks Geoff, I tried that and still can't hear either of the pumps making any noise
Observer
Post by Observer » Mon Apr 07, 2014 11:21 am
blobber wrote:Yes it is possible. I had failure on both, but, one was a seized motor, the other was the motor bushes needed a clean. Even so, battery tray etc has to come out :( :(
Cheers, I'll crack on when it stops raining :wink:
Post by Northern Bongolow » Tue Apr 08, 2014 3:58 pm
usually the motor connections just need a clean up and lube.
