ecu and welding
Paulinwales
ecu and welding
Post by Paulinwales » Tue Apr 01, 2014 9:06 am
Planning on doing a bit of weld repair on underside near exhaust (So well away from battery) where is the ecu located and how best to isolate it incase of harm?
Ps I have read around and some recommend disconecting battery and others suggest keeping it on as it absorbs any spikes any opinions. I have leisure battery also .
Thanks in advance Paul
winchman
Re: ecu and welding
Post by winchman » Tue Apr 01, 2014 10:57 am
I always disconnect the earth as the battery is 12v welders can be different voltages but many are 50-80V.
Re: ecu and welding
Post by teenmal » Tue Apr 01, 2014 11:43 am
What welder are you planning to use.
Paulinwales
Re: ecu and welding
Post by Paulinwales » Tue Apr 01, 2014 7:46 pm
Mig
Re: ecu and welding
Post by teenmal » Thu Apr 03, 2014 9:53 am
Personally I would disconnect both the battery and the PCM, it is situated behind the glove box.
Paulinwales
Re: ecu and welding
Post by Paulinwales » Fri Apr 04, 2014 8:32 pm
Whats the pcm? My bongos a 95 diesel
Cheers for input so far.
Ps I have 2 batteries do I disconnect both? And why?
Re: ecu and welding
Post by teenmal » Sat Apr 05, 2014 9:07 am
PCM =Powertrain Control Module, some peeps call it ECU.
I would personally disconnect all the batteries, it might sound a bit OTT but I would also unplug the Alternator.
redalan1971
Re: ecu and welding
Post by redalan1971 » Sat Apr 12, 2014 9:45 am
The earth leads must be disconnected from both batteries or the welding current will flow to them. Big risk of them exploding.
Paulinwales
Re: ecu and welding
Post by Paulinwales » Tue Apr 29, 2014 4:02 pm
cheers guys will do
looked for ecu thing by glove box seen some diagnostic looking connectors any tips on how tofind the thing . I think i'll play safe with that also
cheers Paul
Re: ecu and welding
Post by Simon Jones » Tue Apr 29, 2014 8:41 pm
As mentioned above, there isn't a ECU as such on earlier diesel Bongos but the control box(es) for transmission etc are under the dashboard:
May also be worth disconnecting the airbag controller too (if fitted).
