Help, roof stuck open 3 inches
roosmith
Post by roosmith » Sat Mar 29, 2014 7:44 pm
My roof is stuck open 3 inches won't go up or down, can't get to motors as not far enough up. Need to use it tomorrow morning at 4!
Re: Help, roof stuck open 3 inches
Post by Doone » Sat Mar 29, 2014 7:50 pm
Start with the basics, have you pressed the button in the roof for the second time?
Or is there something in the way, preventing it closing completely?
Otherwise, check this link: http://igmaynard.co.uk/bongo/forum/view ... wont+close
and
http://www.igmaynard.co.uk/bongo/forum/ ... lly#p47284
Post by Simon Jones » Sat Mar 29, 2014 8:42 pm
Can you hear motors running? If not, it will be an electrical problem so check out the fuse, relay and handbrake switch.
roosmith
Post by roosmith » Sat Mar 29, 2014 10:19 pm
Thanks for the suggestions. The motors were trying to work but something appeared to be jammed.
I managed to get the runners off their tracks and force the roof up enough to get the motors off. The roof still wouldn't go down but without the motors I was able to jemmy the rollers along enough. Its now down but not able to drive it because the roof hasn't locked in place and the beeping!
I was contemplating a permanent hi top. Now might be the time to get one fitted! God knows how I'm going to get fixed without driving it though!
Post by Simon Jones » Sun Mar 30, 2014 10:05 am
You can open both front doors and run a strap over the roof and thru' the cab to hold the roof in place. I've seen a Bongo driven like this with its roof stuck part open. It'll be ok as long as you take it steady.
roosmith
Post by roosmith » Sun Apr 06, 2014 2:14 pm
Right, update time! I managed to get the roof back up manually and process of elimination found one of the motors had failed. Replaced that and it works again. I've always had a problem with low voltage though so took some more time to try and solve that. This is yet another mystery!
Without motors I have 13.5v coming out of the control module. Attach the motors and even without the load of the roof they pull it down to 11.3v. I've taken out the fuses and cleaned them, cleaned all contacts including handbrake but still only 11.3v. And yes that is with the engine running.
Any ideas?
Post by g8dhe » Sun Apr 06, 2014 4:05 pm
Well its quite a long run from battery to AFT, and Mazda were never overgenerous with wire gauges. Have you checked the voltage drop across the relay contacts in the control module ? Try measuring the voltage between 1A and 1C when the roof is lifting and then between 1B and 1D when the roof is lifting
If that is essentially zero difference or less than 0.2 volt then nothing wrong with the relay if its any thing significant above 0.5 volts difference then replacing the relay internally or the module would be the best bet.
after that then only assuming your S/B isn't knackered then only replacing the wiring for much heavier gauge will have any affect, but it really shouldn't be necessary.
roosmith
Post by roosmith » Sun Apr 06, 2014 8:39 pm
Thanks for your detailed reply Geoff. I'm going to have to study the drawing in a bit more detail on my PC, its a bit small on my phone, but I think what you are saying about the voltage across those contacts on the control module is exactly what I did, and they were indeed the same. So points to cable gauge but like you say it shouldn't be necessary really, well you would have thought anyway! Cable shouldn't have degraded that much itself its nearly always the contacts at either end.
I wonder if someone has a spare module for sale somewhere, it can't be that expensive, I might just try changing it. Might save an awful lot of bother, as re running cable isn't going to be easy.
Oh and yes starter battery is less than 2 weeks old so shouldn't be that!
Thanks for your help.
Post by g8dhe » Sun Apr 06, 2014 10:00 pm
You have clocked that the power for the electronics module is separate from the power for the motors and fused separately ?
If its dropping to 11.3 volts without the relay operated up or down then there is something more radically wrong.
roosmith
Post by roosmith » Mon Apr 07, 2014 12:25 pm
Thanks for your continued help Geoff.
Yes, I've checked both fuses, the 15 and 40amp, both slightly tarnished both cleaned and WD40ed!
When you say without the relay operated, I'm not sure I follow.
Both 1A - 1C and 1B - 1D read 13.8v without any motors connected but the switch pushed. I don't know if this is a correct test?! As soon as you connect the motors (but leave them detached from the roof, so no physical load) it drops to 11.3v. It actually makes no difference if the motors are under load or not, if they are connected the control module is only giving 11.3v.
Does that make it any clearer? I'm sorry if I'm trying to dumb it down too much! I have a little knowledge but am fully aware that is a dangerous thing!
Post by g8dhe » Mon Apr 07, 2014 10:18 pm
If the voltage between 1A and 1C drops to 11.3v then that is the voltage from the wiring loom, and indicates that its nothing to do with the module or its relay. You will need to measure the voltage drops going further back towards the battery .. I wonder what the earth connection is like ?
roosmith
Post by roosmith » Tue Apr 08, 2014 12:18 pm
Thanks Geoff, do you know where the earth connection is for this or do you mean for that battery?
Post by g8dhe » Tue Apr 08, 2014 5:41 pm
The two earth connections are 11 and 9 on the diagram below;
11 at the rear possibly below the module, 9 is less obvious, but might be around the engine.
I would measure the voltage drop in both the earth and 12 supply separately and see where the volts are being lost whilst the motors are connected and powered. Make notes of the drops and then starting with the highest voltage drop take a look at all connections between the measurements.
Start at the battery and measure the voltage between the -ve post on the battery itself and the chassis connection for the battery, next earth point 9, then earth point 11, then Pin 1A on the module, hopefully no single point will be more than 0.1 to 0.2 volts from the previous.
Now measure the volts from the +ve post to the 30 Amp motor fuse, then Pin 1C on the module, again ideally it should be less than 0.1 to 0.2 volts at each point.
However one or more of the readings should be a lot higher to give the 1.2 volts drop your getting from 13.5 to 11.3 volts. After that its a case of concentrate on each joint/fuse etc. where its being lost. As a check do measure the voltage at the battery posts as well under load, just in case the new battery is the problem!
