reverse gear
Baz and Helen
reverse gear
Post by Baz and Helen » Thu Mar 20, 2014 9:22 pm
Hi thought I"d give you an update on our reverse gear problem. Turns out the reverse clutch hub bush was damaged which in turn damaged the pump body , so had to have new clutch hub with pump reseal and re-plate hub and pump new filter and fluid.
So £1320.00 we are back on the road and hoping not to have any more problems for a while.
thanks for all your help
Baz and Helen
Re: reverse gear
Post by Bob » Thu Mar 20, 2014 9:35 pm
Well done, thanks for the update. :)
