I have just purchased a Mazda Bongo with a side conversion,
Installed in the side conversion is a electric panel called a PMS34,
which is for basically switching the power source between car\leisure battery,
and switching on\off the water pump etc...
Was just wondering if anybody on here, has a copy of the manual for it ?
Thanks...
Instruction Manual For PMS34 ?
- Simon Jones
Re: Instruction Manual For PMS34 ?
Google is your best friend when it comes to this sort of thing. This link came up quite readily which includes instructions for PMS3 which appears to be much the same: http://codfangler.blogspot.co.uk/2009/0 ... rived.html
I had already googled this,and found the same link as yourself.
Wasn't sure if it was the correct manual for it,but like you say,
It's probably close enough.
Thanks.
Thanks.
These are the instructions from my old Bongo. Probably not quite the same model but they may help you a bit.
Tony
Tony
- Apprentice Bongonaut
There is no PMS 34.
It’s a PMS 3H for horizontal.
The typeface on the unit makes the H look also like a 4 which it isn’t.
The manual is available at
https://www.olearymotorhomes.co.uk/ekmp ... ctions.pdf
Steve
Steve
