What is this and why is it dripping?
Posted: Mon Mar 17, 2014 8:58 am
by Banjoblue
There's a drip from the tube at the top of the picture, it looks like a square plastic plug sealing the end of a pipe. Anybody know what it is?
Re: What is this and why is it dripping?
Posted: Mon Mar 17, 2014 9:09 am
by Gasy
Do you have a conversion fitted?
If so might of had rear heater / air on removed and that pipe is what used to feed one of them
Posted: Mon Mar 17, 2014 9:08 pm
by Northern Bongolow
if you mean the pipe thats bent back on it self and secured via the plastic hook, thats the end of the bleed pipe.
sometimes the clip eats its way into the pipe wall, or can get damaged rubbing on something, it looks like its been routed in an odd manner. examine it carefully, if its to be removed to be fixed or shortened seek advice as you may have to bleed the coolant system if you are not careful.
Posted: Mon Mar 17, 2014 10:17 pm
by Driver+Passengers
http://mazdabongo.wikispaces.com/Parts
Engine bay (nearside), part (3). That's the bleed hose - is that what you're looking at? ie not what your finger is pointing to...?
Posted: Tue Mar 18, 2014 9:44 pm
which engine is it ?, it looks petrol, not that it matters it still looks like the bleed pipe.
Posted: Tue Mar 18, 2014 10:00 pm
by Simon Jones
That'll be a V6 then. There should be a plastic clip on the rocker cover which keeps it up out the way. The end with the bung can neatly be cable tied to the wiring loom.
Posted: Thu Mar 20, 2014 6:45 pm
bit scruffy that engine bay :roll: .
looks like its routed the same as simons pics. :)
Posted: Thu Mar 20, 2014 8:37 pm
by Bob
[quote="Northern Bongolow"]bit scruffy that engine bay :roll: .
:D :D :D
Posted: Thu Mar 20, 2014 10:34 pm
by Simon Jones
Yes, there's quite a bit going on there. Got even more pipework at the top end for the LPG:
Posted: Mon Mar 24, 2014 11:10 am
by Banjoblue
Thanks all - that's really helpful.
