unconverted camping stuff
Moderator: Muzorewa
been-and-bongo
Post by been-and-bongo » Sun Mar 16, 2014 7:52 am
Hi what do people use to boil kettle in a unconverted bongo?
I'm currently on first bongo trip and as weather is fab I've used my suitcase stove outside but not sure what to do if it rains (have cooking tent if staying 2+ nights)
I have electric lead but haven't plugged it in as didn't want to leave a window open.
Any thoughts most appreciated
Are we human, or are we campers?
Gasy
Re: unconverted camping stuff
Post by Gasy » Sun Mar 16, 2014 8:03 am
Fold your middle bench seat down and put your cooker on the hard back of seat
Put your elec lead through your back door and just close it gently
Post by Simon Jones » Sun Mar 16, 2014 10:09 am
We sometimes use a mains travel kettle when on hookup. Just enough for two cups of tea.
Dr Fingers
Post by Dr Fingers » Sun Mar 16, 2014 10:52 am
This does it for us, anywhere, anytime.
http://www.argos.co.uk/static/Product/p ... 099562.htm
Derek
winchman
Post by winchman » Sun Mar 16, 2014 11:59 am
I made this
Post by mikeonb4c » Sun Mar 16, 2014 2:31 pm
Dr Fingers wrote:This does it for us, anywhere, anytime.
Derek
But not in cold weather, as I found, when the gas was too cold to vapourise properly and I had huge orange flames licking up around my frying pan. A bit scary!
winchman
Post by winchman » Sun Mar 16, 2014 4:09 pm
You might be able to get propane mix gas cylinders for these stoves, they will tolerate colder weather but if its cold use a trangia etc but not the fastest to boil, we have a Jet boil with a propane mix cylinder but as the gas cylinders so small you can warm it by placing it in your pocket
Alison01326
Post by Alison01326 » Sun Mar 16, 2014 9:38 pm
If you are worried about melting your seat back, use one of these tables http://www.amazon.co.uk/Gelert-FUT152-B ... B00132D8G2
I usually just open the boot lid and stand under it if it's raining when I brew up. I've got a Trangia cooker which negates the issues of whether the gas will work or not (it runs on meths), but I've had it for ever (almost). Unless you're going to use one a lot, they are a bit pricey.
The table, on the other hand, at £9.99 is in my top ten "bits of useful kit for camping"!!
Alison
Post by Bob » Mon Mar 17, 2014 2:15 pm
I made up a method of fixing the table from in front the middle seat onto the bracket for the bike rack.
Sits nicely under the tailgate.
Dr Fingers
Post by Dr Fingers » Mon Mar 17, 2014 2:18 pm
Derek
Well, we just use ours for a brew up in the van. Must admit I've not used it in 'Arctic' conditions!
Derek
Post by mikeonb4c » Mon Mar 17, 2014 8:09 pm
Derek
Derek
Be careful - wouldn't want my experience inside the van! :shock:
fatcatlawyer
Post by fatcatlawyer » Mon Mar 17, 2014 9:38 pm
I remember seeing a post that showed how to make a cooker from a drinks can, that would work with meths. Cannot recall where I saw it exactly but I am sure it was some where on here.
Ian G
briwy
Post by briwy » Tue Mar 18, 2014 12:50 am
fatcatlawyer wrote:I remember seeing a post that showed how to make a cooker from a drinks can, that would work with meths. Cannot recall where I saw it exactly but I am sure it was some where on here.
Ian G
Here you go Ian
http://www.outdoorsmagic.com/gear-featu ... /6227.html
BTW, anyone using using any kind of stove in the van make sure you have adequate ventilation, death can be fatal. :!:
winchman
Post by winchman » Tue Mar 18, 2014 7:19 am
Alison01326
Post by Alison01326 » Tue Mar 18, 2014 12:45 pm
winchman wrote:Good quality copy of a Trangia
http://www.clasohlson.com/uk/Asaklitt-S ... ve/34-3320
The scoundrels, fancy copying the Holy Grail of camp cooking equipment (in my opinion)!!!! Good find, though, Winchman, and LOOK at that price!! About the same as one of those little gas cooker jobbies and probably cheaper to run and more versatile. Never come across Clas Ohlson or Askalitt before.
Alison
