Rattling Tail Gate / Back Door
Sparky6911
Post by Sparky6911 » Fri Mar 14, 2014 9:18 pm
Hi All,
Just wondered if anyone else has experienced a really annoying rattle from the rear door.
I have done a google search for this with no results.
Both of the rubber bump stops are in place, there is a small piece of the squidgy rubber door seal missing but the sold piece that attached to the metal flange is still there.
Is it possible to move the door lock to tighten up the door against the bump stops and door seal?
Thanks in advance
David
wonkanoby
Re: Rattling Tail Gate / Back Door
Post by wonkanoby » Fri Mar 14, 2014 11:01 pm
from recall its the catch ring bit on the floor you move
and in my case in the opposite direction you would have thought
as the lock was only taking its safety hold as it had been moved to far
once moved it would fully latch
Post by Northern Bongolow » Fri Mar 14, 2014 11:45 pm
another thing that affects the back door closing properly is the spare wheel carrier. if its been pulled up too tight it easily distorts the rear cross member which can cause the rear door to alter its catch point.
loosen the spare wheel slightly so the spring relaxes a little.
bongo frenzee
Post by bongo frenzee » Sat Mar 15, 2014 11:03 pm
The tailgate door on my Bongo never used to shut properly and rattled, until I discovered that the pull-strap was getting trapped in the door seal. I taped it up to the door panel with gaffer tape and problem solved!
Living for the weekends...
CUIDADO! VEICULO BONGO!
