Fridge help
The Spyers's
Fridge help
Post by The Spyers's » Fri Mar 14, 2014 5:29 pm
Being a newbie and female, can anyone advise how we get our fridge on our Freda working. Had a guy at waeco take a look and he couldn't work out the control panel in the rear either. Any help is much aprreciated.
briwy
Re: Fridge help
Post by briwy » Fri Mar 14, 2014 6:14 pm
First thing to do is check any fuses you can find on the control panel and check the voltage as fridges won't normally start up if the voltage is down a bit.
Usually the fridge takes a feed from the wires which come from the leisure battery to the control panel BUT the fridge feed doesn't actually go through the control panel.
It could be that there is a fuse hidden away somewhere in the wiring to the fridge, our first Bongo was like that and it took me ages to find the fuse.
Re: Fridge help
Post by Simon Jones » Fri Mar 14, 2014 10:05 pm
What sort of fridge and conversion do you have?
alan
Re: Fridge help
Post by alan » Sat Mar 15, 2014 12:07 am
hi there think the frist thing is to take a pic and up load it so those it the know not me can help you
take it easy drive a bongo
Re: Fridge help
Post by g8dhe » Sat Mar 15, 2014 12:51 am
Yup name and type of convertors, also do you have a ZIG unit if so what model number or is it a PMS unit for the EHU you have ?
