Fuse Identification
- Apprentice Bongonaut
Fuse Identification
I have lost windscreen wash, need to check fuse. Require a name and numbered fuse chart.
- Simon Jones
Re: Fuse Identification
If you're a fully paid up member, there is complete list of fuses in the factsheet: http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
It's number 15 on the dashboard fusebox but that does wipers as well, so it sounds like your pump has failed which is quite a common problem. You can sometimes repair them, although you can get a replacement pump for about £10 which is a lot simpler. Lots of info on how to sort this via the search facility.
