My hooter has stopped hooting!
Ruthyadams
Post by Ruthyadams » Tue Feb 25, 2014 4:51 pm
Horn suddenly stopped working and as my manual is in Japanese.......
No idea how to fix it.
If you do, please help :D
Re: My hooter has stopped hooting!
Post by Bob » Tue Feb 25, 2014 7:31 pm
I'd start with the fuse, but of course I can't remember which one it is.
Someone will soon help out. :)
Post by g8dhe » Tue Feb 25, 2014 10:25 pm
Its normally the connections at the horn that have rusted away rather than the fuse, its the most forward thing on the vehicle and gets all the spray over it! However the fuse is a 10 Amp (Red);
David Edwards
Post by David Edwards » Fri Feb 28, 2014 7:56 pm
mine has too, I think it is the same relay as the headlights and this was a bit dicky so gonna get it checked
Post by Northern Bongolow » Sat Mar 01, 2014 8:22 pm
if you remove the front grill and drivers side headlight you will see the wire from the loom (low down behind the under headlight panel) this is the positive supply, check its live when the horn is pressed, then there is a short earth wire to the body.
if twin horns are fitted the positive then jumps across the top of the rad to the passy side horn.
the connections usually just get crudded up.
Ruthyadams
Post by Ruthyadams » Thu Mar 06, 2014 7:40 pm
Thanks Peeps. Will get checking. I hate not being able to Paaaaarp!
