Khyam Motordome
Moderator: Muzorewa
Khyam Motordome
We currently have a Fiamma Privacy Room which we are thinking of changing for a Khyam Motordome. Does anyone have a view as to which model works best with the Bongo? We are planning to leave the Fiamma awning attached to the van to use when we are not using the annexe. Is this likely to cause a problem when attaching the Khyam? Thanks for your help.
						- B*Witched Blingo
Re: Khyam Motordome
Hi. I have both. I have had no issues attaching the Khyam with the Fiamma insitu. You have two options really, the first is the standard fig of 8 plastics which should still clip to the gutter or you can use the optional extra available on the web which is a strip that has a double ended sliding strip. One is small enough to thread into the end of the Fiamma. This is the same diameter as the Privacy room thread rope. The other side is thicker, same as a standard awning thread rope. You will still need the fig of 8 to join the Khyam. Hope that helps you.
									You Tube Films Click Here
- B*Witched Blingo
Re: Khyam Motordome
I think it is called a kadar strip.
