changing side light bulbs
khisanth
Post by khisanth » Sun Feb 16, 2014 1:46 pm
wear suncream
Private
Gender: Male
Posts Per Day: 0.13
Time Online: 15 hours 3 minutes
I am trying to change one of my sidelights in my 1997 bongo. I can access the connector to the right of the headlamp which is easy to unplug but as for getting at the bulb or holder its in I seem to be at a loss. Any help on changing the sidelight bulbs would be greatly appreciated
the laird
Re: changing side light bulbs
Post by the laird » Sun Feb 16, 2014 2:16 pm
I normally remove the side light unit,screw at top pull out change bulb and refit
khisanth
Post by khisanth » Sun Feb 16, 2014 2:57 pm
My sidelights are in the same unit as my headlight
mikeWalsall
Post by mikeWalsall » Sun Feb 16, 2014 3:05 pm
Strange if they are .. unless some one as made there own mod. they are usually in the same unit as the indicator bulb ..
Post by Simon Jones » Sun Feb 16, 2014 3:40 pm
Khisanth, this probably won't help you unless someone has fitted the later facelift units where they are in the main body of the head lamp and fitted into an extension tube:
You can just it to the left of the adjustment motor:
khisanth
Post by khisanth » Sun Feb 16, 2014 3:52 pm
This is my headlights and on the 2nd picture you can see the sidelights
Post by teenmal » Sun Feb 16, 2014 4:16 pm
khisanth
Post by khisanth » Sun Feb 16, 2014 5:33 pm
Turns out once lights unplugged the holder needs to be rotated.
Was unable todo this so undid 1 screw holding grill
And 3 bolts holding lights in got a pair of pliers and gently rotated
Installed bulb and reattached bolts all done.
Thanks for all the help
Post by Simon Jones » Sun Feb 16, 2014 5:42 pm
Those are the later headlights that were fitted form 1999 - late 2001
