Moderator: Ian
stuc
Post
by stuc » Wed Feb 12, 2014 10:01 pm
Eventually got around to fitting a new reversing camera, £7.99 off ebay, full colour and also colour at night, great quality picture. Well happy!
Post
by Bob » Wed Feb 12, 2014 10:05 pm
Crikey, that looks a bit of all right.
stuc
Post
by stuc » Wed Feb 12, 2014 10:15 pm
Cheers Bob, really easy to fit as well, + & - from reverse lamp and one rca cable to the back of the head unit from the camera. It even came with the hole cutter for the bumper.
the1andonly
- Tribal Elder
Post
by the1andonly » Wed Feb 12, 2014 11:21 pm
A link please
at that price it didn't include the display??
khisanth
Post
by khisanth » Sun Feb 23, 2014 9:16 pm
Hi where did you thread the cable to get it into the bongo as i am looking at fitting one myself and cant find a gromit in which to get it into the vehicle.
Post
by g8dhe » Sun Feb 23, 2014 10:28 pm
There is the proper route here;
or if that gets filled up then there are identical holes on the nearside as well, you can make use of but have to make your own rubber boot!
stuc
Post
by stuc » Sun Feb 23, 2014 10:51 pm
My camera is in the bumper as shown and there is a grommet in the off side rear floor just behind the panel below the rear seatbelt mount. Just undo the seat belt bolt, pull the panel off slightly, remove the black cover on the end of the seat rail so you can lift the carpet out the way. You need to lift the sponge insulation and the grommet is on the floor. Didn't even have to take the bumper off to fit it.
Guru
- Bongonaut
Post
by Guru » Sat Mar 15, 2014 10:59 pm
Stu, that looks lovely.
What display unit is that? I need to get something similar.
Andy
RobEvans
Post
by RobEvans » Sun Mar 16, 2014 1:41 pm
Top job stu
stuc
Post
by stuc » Sun Mar 16, 2014 10:20 pm
Guru wrote:Stu, that looks lovely.
Andy
Its, an Xtrons double din head unit, not sure what model but it is an older model now, but it works well. I could get the model no off it if you want it.
stuc
Post
by stuc » Sun Mar 16, 2014 10:22 pm
RobEvans wrote:Top job stu
Cheers Rob, how you doing, are you going to the Bash this year? Would still fancy a set of templates if you have time.
Guru
- Bongonaut
Post
by Guru » Sun Mar 16, 2014 10:33 pm
stuc wrote:Guru wrote:Stu, that looks lovely.
Andy
Did not want to hijack the thread but you sound like you know your way around with the electronics!
I am after a double din - Have only just found out that is what they are called..... Just so many different types available.
stuc
Post
by stuc » Sun Mar 16, 2014 10:39 pm
I have basic knowledge, all are pretty easy to fit, just follow the instructions. If you need help just post on here and I am sure someone will be willing to help.
RobEvans
Post
by RobEvans » Tue Mar 18, 2014 7:38 pm
stuc wrote:RobEvans wrote:Top job stu
Yes going to the bash. Haven't forgotten about templates just had a few issues recently. I'll message you on fb
