Courtesy Lights
Moderator: Ian
khisanth
Courtesy Lights
Post by khisanth » Thu Feb 06, 2014 6:51 pm
does anyone know what bulbs are in the front courtesy light and if so do they know if there is an led alternative
jimmo62
Re: Courtesy Lights
Post by jimmo62 » Thu Feb 06, 2014 6:57 pm
Yep I replaced mine with these and they are good!
http://www.ebay.co.uk/itm/221151932533? ... 1439.l2649
I also replaced the luggage bay bulb and the one in the lifting roof with these
http://www.ebay.co.uk/itm/330710019129? ... 1439.l2649
khisanth
Re: Courtesy Lights
Post by khisanth » Thu Feb 06, 2014 7:13 pm
jimmo62
Re: Courtesy Lights
Post by jimmo62 » Thu Feb 06, 2014 9:26 pm
Forgot to say, LEDs obviously only work one way round so if they don't light up just turn them round. You may need to adjust the wire tails on the W5W bulbs - look into the bulbholder, check where the metal contacts are and bend the wires so they are in the right position (it's obvious when you do it!)
wonkanoby
Re: Courtesy Lights
Post by wonkanoby » Mon Feb 10, 2014 8:41 pm
MarcT77
Re: Courtesy Lights
Post by MarcT77 » Mon Feb 10, 2014 10:56 pm
Whilst on this subject,is there a way to get the rear light to come on with
the front courtesy lights when opening the drivers or passenger doors ?
Re: Courtesy Lights
Post by Bob » Mon Feb 10, 2014 11:12 pm
It must be possible, I just don't know where the wires run.
It would be very easy to fit an extra light in the back 'Piggy Backed' off the front light.
Return to “Pimp My Bongo”
