Fresh water tank
Mal-53
Fresh water tank
Post by Mal-53 » Wed Feb 05, 2014 10:15 pm
I have a side conversion. Does anyone know whether the fresh water tank has a drain plug/outlet. Someone has inadvertently filled the tank with diesel and I need to drain it out! And flush it of course. Any other suggestions as to how this can be done inexpensively will be much appreciated.
Re: Fresh water tank
Post by Bob » Wed Feb 05, 2014 10:31 pm
What make conversion is it?
I honestly recon you'll have to replace the tank and pipework, just don't think the smell or taste will come out.
Bad luck. :(
Gasy
Post by Gasy » Thu Feb 06, 2014 6:44 am
As above that's had it know
You could try fernox LP sterox
It's a silver based tank cleaner safe to drink etc
We you it's to clean water tanks for legionella protection
It would be good for conversion water tanks once a year or more it's safe to leave in best to flush tho
Don't think it will clear diesel tho
winchman
Post by winchman » Thu Feb 06, 2014 7:53 am
You would need a degreaser first to remove the diesel, then have the challenge of removing the degreaser but to be honest I would just change the tank
Post by Simon Jones » Thu Feb 06, 2014 9:29 am
Change the tank - you'll never get rid of the taste or smell of diesel. Depending on what conversion you have will determine level of difficulty. Imperial in their conversions, it is mounted vertically behind drivers seat & would take about an hour to remove. Wellhouse put in the area where rear heater used to fit so will probably require the whole unit to be removed:
Next step, change the wife/husband/partner/friend who did the damage :)
Mal-53
Post by Mal-53 » Thu Feb 06, 2014 8:30 pm
Thank you for all your replies especially the last one. Still not sure how to get the diesel out to start with, guess it will have to be syphoned.
Diplomat
Post by Diplomat » Thu Feb 06, 2014 9:02 pm
I thought only the teachers I used to work with did that kind of thing!
Frank
They flew, I took up naturism
Tessie
Post by Tessie » Thu Feb 06, 2014 10:09 pm
Simon Jones wrote: Wellhouse put in the area where rear heater used to fit so will probably require the whole unit to be removed:
Wellhouse don't always fit in the position mentioned by Simon as above. My Wellhouse conversion water tank is fitted to the chassis under where the side sliding door is and is quite easy to get at, it is held on by two straps. If yours is a Wellhouse I hope it is like mine and not like the one above.
Never run out of road, traction and ideas at the same time.
Post by Bob » Thu Feb 06, 2014 11:23 pm
Mal-53 wrote:Thank you for all your replies especially the last one. Still not sure how to get the diesel out to start with, guess it will have to be syphoned.
That's cheap and simple. (Like some girls I've been out with.)
hijimhere
Post by hijimhere » Fri Feb 07, 2014 4:17 pm
If I have a functioning rear heater am I ok to assume there no tank behind the driver seat!
Post by Simon Jones » Fri Feb 07, 2014 4:33 pm
If you've got an Imperial conversion & the filler cap is accessed by tilting the drivers seat forward, then there will be a vertical tank which you can access by taking the worktop off & disconnecting gas, electrics and water
Mal-53
Post by Mal-53 » Fri Feb 07, 2014 9:31 pm
For all those that asked I have found out that it's probably a 'Clumber' side conversion carried out by Outback Autos in Norfolk. The tank is adjacent to the fuel tank. It has a filler cap that looks like a fuel filler cap, hence the error.
GrayRX8
Post by GrayRX8 » Tue Feb 11, 2014 5:45 pm
For what it worth my son in law did the same thing only with petrol took the tank out tried all manner of cleaners solvents - ended up changing the tank.
Cheers Gray
Mal-53
Post by Mal-53 » Wed Feb 12, 2014 9:34 pm
Problem solved- new tank, pump, pipes & locking filler cap! Very expensive mistake
Thanks again for replies.
Anyone want to buy a Bongo?
Post by Bob » Wed Feb 12, 2014 9:40 pm
At least you're sorted.
Many people miss-fuel so it could have been worse.
