FUSES!!
FUSES!!
Does anyone have a fuse diagram that is in English??? Travelling home last night and majority of the dash light went out along with the rear lights!! Went to change the fuse..............bugger me!!
Its under the bonnet.. i think!
Hi francofontain
The fuse you need to replace I believe is actually under the bonnet not in the panel to the right of the steering wheel. Im just guessing that you may have thought it was there?. I went though all the fuses trying to fix this same problem its a 15Amp Blue fuse under a black fuse cover almost in the centre of the bonnet compartment. I think its marked up real lights or something. I believe sometimes people fit a fog light to this same circuit which can cause the fuse to blow.
Stuart
Stuart
