heater blowers stopped working
- mellon man
Help please - Both front and rear heater blower fans have just stopped working.
Fuses are OK
Any ideas what it could be ?
						Fuses are OK
- Simon Jones
Re: heater blowers stopped working
Which fuse(s) have you checked? The 'heater' is on a 30A fuse, number 17 under the bonnet. There is also number 15 described as 'rear heater' according to the factsheet: http://www.igmaynard.co.uk/bongo/member ... usebox.pdf
						- mellon man
Yes Simon that's the ones big pink ones and they were fine.Simon Jones wrote:Which fuse(s) have you checked? The heater are on a 30A fuse, number 17 under the bonnet. There is also number 15 described as 'rear heater'
- Simon Jones
Ok, have you tried them on a speed settings? Blown resistor pack usually only affects lower speeds. Have you tried removing the front ducting and spinning the fan round by hand? The bearings tend to get quite a soaking especially if the scuttle drain hole gets blocked up.
Have you got digital or manual controls, and is the 'rear' switch on the dashboard in the on position?
- mellon man
No not checked anything else hoping it might be something simple as working fine yesterday.Simon Jones wrote:Ok, have you tried them on a speed settings? Blown resistor pack usually only affects lower speeds. Have you tried removing the front ducting and spinning the fan round by hand? The bearings tend to get quite a soaking especially if the scuttle drain hole gets blocked up.
Will go through your check list - How do I access the fans ?
It has the manual controls. Thanks..
This happened on ours - thee is a arm on the centre console drivers side footwell that became un clipped. I clipped it back on and it started to work again.....
									Be the change you want to see in the world....
						- mellon man
O.K. found this from Rhod in 2008:
The fan is located on the right hand side (looking from the front) under the bonnet. It's inside the round plastic housing below the heater air intake.
I'm writing from memory, but the way that worked for me was roughly:
1) Remove 2 push-clips at front of "wide-mouthed" ducting & pull ducting off.
2) Disconnect fan electrical connector.
3) Unbolt fuse box & lay to one side
4) Undo 2 nuts (horizontal) behind fuse box which hold ducting on
5) undo 3 screws (vertical) holding the fan housing/ducting - 1 on right, 2 on left.
6) undo 2 nuts (horizontal) at the rear right holding the fan housing/ducting to the rear bulkhead.
7) Lift & manoeuver the plastic ducting/fan housing assembly out of the bonnet space
8. undo 3 screws on the underside of the fan housing to extract the fan.
Think that's it - I might have missed a screw or bolt out but it's all self explanatory. Don't think it makes any difference which order you unbolt it in really.
- Simon Jones
No need to go to those lengths to check the motor spins freely. Locate the ducting shown in the dotted line half way down the left hand side: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
This is held in place by two scrivets:
Prise or unscrew the centre pin, remove scrivets and pull the ducting off. You will then be able to see the fan in the housing. H&S warning: make sure the ignition is off before sticking your hands into the fan blades
Plenty of reading material under the FAQ section: http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=28727
- mellon man
Strange - the front heater or rear heater fan not working but when the turn control ion the front is on number 1 the rear fan comes on but if I turn the control to 2-3 or 4 the rear fan  turns off with nothing happening with the front fan
I'd check resistor pack as it sounds a bit like it might be the culprit, from the symptoms.
						- mellon man
Thanks - where will I find the resistor packmikeonb4c wrote:I'd check resistor pack as it sounds a bit like it might be the culprit, from the symptoms.
On the facsheet in the members area. I did mine years back - dead simple but remember the underlying cause needs to be fixed or it will happen again (partially seized fan due to water ingress from blocked windscreen drain)mellon man wrote:Thanks - where will I find the resistor packmikeonb4c wrote:I'd check resistor pack as it sounds a bit like it might be the culprit, from the symptoms.
- mellon man
On the fact sheet in the members area. I did mine years back - dead simple but remember the underlying cause needs to be fixed or it will happen again (partially seized fan due to water ingress from blocked windscreen drain)[/quote]
[Update/b]
In between showers removed resistor all 5 connections had separated soldered back together as per fact sheet.
Now as per your advice need to find out what caused them to blow, did notice that with bonnet open rain water was dripping on in the area of fuse box & resistor housing, so start with drainage and then fan movement.
Will keep those interested updated
Thanks..
						[Update/b]
Thanks..
Front blower motor will have partially seized due to water falling on it from blocked drain on windshield gutter (which needs a wire poking through it at regular intervals to keep it clear). Hopefully you'll be able to strip it and clean things up like wot I dun.
						- mellon man
UPDATE 2 :
Drain hole and pipe unblocked and cleaned
Tried motor but was struggling only any sort of air output at settings 2 & 3
Front air intake cowling removed to access fan, fan blades did not seem all that easy to move
Removed top cowling & fan housing (straight forward once moved fuse box & It's mounting plate)
Removed fan from rear of It's housing, but unable to access bearing
Took off motor back cover, full of rust inside cleaned it all off and reassembled motor put some grease in dimple in alloy back cover, fan was must freer to move
Cleaned all dirt and dust from fan blades (this took longer than all the rest of this repair) !
Cleaned levees and debris from front of heater rad (should there be some sort of gauze filter on here to stop this happening)
Put all back together and fan now works brilliant at all speeds
Just in time as had it working flat out as only 2oC today
